twin sizing
onebadcoastie
Elizabeth City, NC
Do you have an idea of what size injectors you're planning on running? Hybrids/conventionals? dual oil pumps? Gonna take more than just a couple of turbos to get there.
stroker57
frostburg,MD
Hybrid 430/150s and dual pumps already on the truck with a single s475 look for something alittle more street fun this will be buy no means a dd if it gets 1000 miles a year put on it its lucky
onebadcoastie
Elizabeth City, NC
You could keep that 475 as the low pressure turbo and run a 67 or 68mm high pressure turbo but even then, those seem a bit small for 430/150's or 850-1000hp. maybe the 475 as a high pressure and a 91mm as a low pressure as suggested earlier...
windrunner408
I think you have the fuel department covered. LOL I think figuring out the air will be the key here for sure.
Pizza pig
MD
Yea got plenty off fuel just got to figure out what turbos will work the best
66/88 is enough air to get you there, but only one problem, its a 6.0... Its going to be hard without spray
Hellen Keller sent this?
Dzchey21
wyoming
I dont know how 6.0s are but i say 90 ish on the low pressure and 62-64 on the high pressure so it spools pretty fast, looks like you have plenty of fuel so i would be looking at a 94mm gt55 if you have the coin
stroker57
frostburg,MD
What Im looking for is something that will spool pretty good and not be a total pig on the street and still be with in my hp goal if possible. How would a 471 Gt55 spool like ?
Dzchey21
wyoming
471 is going to be somewhat laggy
personally i would stay 66ish sized gotta remember it takes boost to make boost
