U bolt question
91turbogsx
Gardner MA
Anyone out there have different length ubolts for these trucks yet? I just want to put F350 blocks in the back of someone's F250 and I was just going to buy new ubolts from Ford but since the F250 doesn't have overload springs and it appears that all F350's do, the ubolts are too long with not enough thread.
Anyone run into this scenario? Doe's a ubolt from 99-10 work although they are upside down?
NotStock
Tucson, AZ
We have a ubolt bender and can bend pretty much any size you might need. Like Kaden said, you might check with a local spring shop first.
-Trevor
91turbogsx
Gardner MA
How much would you charge for a set of ubolts Trevor? My nearest spring shop is a good distance away and I find it easier if they just come to my doorstep. LOL
I have yet to measure the stock F250 ubolt but it would need to be that plus 2". I don't believe they are a constant radius like the older trucks.
NotStock
Tucson, AZ
They are not a round bend, they are a semi round configuration. They would be $75 for the set.
