Might have missed it but what fuel are you running?
Stock fuel. New reman OEM HPFP.
I have a LPFP to put on as well, just havent done it yet.
What air intake do you have on it ?
Clean filter ? A clogged filter and or a intake that doesn't flow enough ( not in this case ) will effect power. Does it suck the filter minder in after a run ?
Running a new tune with a little more timing and it feels a little stronger. It was 55 degrees Saturday night and peak boost was 52psi. Hope to get new track times this Friday and see how the timing helped.
We tried more PW too, but rail pressure drops to 23k and PW on the minaxx says 2298us at WOT even though tune commands 2400.
Those numbers sound better. Not sure what's happening with the pw and rail pressure but most hot tunes only command 2.2 ms iirc. do you know what timing youre running? those turbos should easily handle stock fuel.
Hell I say toss your new LP pump on and see if it has any effect then.
You need a fuel line tool or AC line tool will work too.
Got those off fine, its the stupid blue clip push button ones I cant get.
Ha those are the easy ones, just push them in ( one button on each side of the line ) and slide it a little towards the pump and pull back away and it should slide off.
Yep one per side. Let us know the results.
Increasing pulsewidth is not going to help your low rail pressure scenario. You are leaving power on the table if it is not maintaining 25500-26500 ksi
