NDsuperduty
I have a 6" basic fabtech kit(all drop brackets, uses factory radius arm, rear blocks) with a 2" coil spacer. The truck rides ok, but its a little stiff (as you would expect from a 1ton truck). The truck handles ok, but does have a little slack in the steering. Not sure if this is from the lift or just wear and tear after 100k miles. I am wanting to upgrade the suspension so it will ride better, but I'm not looking to go crazy with some $6000 OUO kit. The truck never goes offroad, so the only thing I care about is what will make it ride better on the highway and around town, without losing much,if any, load capacity.
I know some of the different options out there..coil-overs, progressive rate coils, 4-links, etc.....but not sure which options would be best for what i need
