used 6.4 engine
wiseguy
northern IN
used 6.4 engine. 9000. this engine is complete turbo to oil pan automatic never tuned. 68,000 miles 2167 hours oil changed every 3k always ran mobil one synthetic relative compression 0% hpfp test passed contribution ok short fuel trims ok. koeo pass no dtcs was NOT WRECKED..... oil analysis done last service ..I tried to check this out best I could. only notable problem rear crank seal had small drip. To ensue best possible engine new seal already installed. engine is bolt in ready. harness included. truck did not have fifth wheel or snow plow. This is probably the best used 6.4 available. shipping negotiable engine is on pallet for immediate shipment. I am not here often Please text 5743037503
wiseguy
northern IN
ok ok! was out of customers truck wanted built engine rcd cam kit hd pistons studs deleted emissions ect . we built core motor for the truck could not see tearing down perfect running engine.
