V10 to 7.3L Excursion
Copracr
Small update
I started retracing wires to get the oil pressure and tach working when i noticed one wire is WH/PK and the other is WH/RD. Sure enough I got them backwards cause they look nearly identical. I switched them and they both work now. Except the V10 tach reads high. at 700 or so RPM's it read out 1000. the ratio seems to stay pretty constant. I tried cutting the ground for the v10 tach select but that did nothing. I tossed the diesel cluster in and it read accurate so i will need to grab a diesel cluster with about 140K on it to keep things right.
I also found the FR headlight blew out. When I dug into that part of the harness I found there were 2 GR/OR wires and I got them backwards. Now I have both headlights and cruise control. Besides the a/c line and the gas filler neck I am done with the conversion now.
rpm-inc
The cluster isn't the digital odometer, right? You can pop out the odometer and put it in another cluster. I have done it a few times. And I have a couple diesel clusters laying around if you need one.
Copracr
I think it was digital, but thanks for the info guys. Unfortunetly I sold the Excursion though. A guy came along and offered the right price on it. I miss it already, I might get another one in the future cause I already regret selling it. I want a 2wd next time though, and a manual trans, and a ......
Wayne
Twin Falls, Idaho
If the right deal came along for a manual 6.4 for my excursion, I would be really tempted. Manual is cool to me just because you don't see it much, especially in an excursion. :rockon:
co04cobra
WV
I would do the manual swap into a ex for around 10k. That would be including the price of the trans, t-case, pedals, floor hump, etc....
EXUSEME
Sounds awesome! This is my first post
And I'll be doing well having a shop do my swap
Got a o2 f250 v10 with 24k, and lost the motor
After my Ol started it for me while out of town
Working and oh man she locked the truck while
It was covered and running. By the time aaa showed
Up the truck had quit running... 7.3 here I come!!
EXUSEME
Found a 01 7.3 with 9k on it for a totaled truck
This is a list and why I'm having the diesel
Installed... 10.5 in lift all custom 4link 3bypass
kings front and rear, mt beadlocks rapped w 38s
Fiberglass sides and hood. For sale is the complete motor.. Doug thorly
Thick flange v10 headers, injectors, supercharger, it's
One bad mo fo!!!
It just overheated once ouch lol
EXUSEME
Not trying to sell anything but this site has my truck
As the back ground. If you like truck you WILL
Love mine!! Check it out
