Vacuum pump+Oil leak=????
BigJDW
Daytona Beach, FL
So i found an oil leak between vac and ps pump. When i pulled the vacuum pump to see where its coming from but it was coming from the shaft on the pump. Thought maybe it sucked it up some where but i didn't see where it could. Any one know where it came or had this problem before?
MossBack
UTAH
Could be the grease leaked out of the needle bearing inside the vacuum pump. Next is that bad boy is going to grenade soon better swap it out.
Sent from my iPhone 4s using Tapatalk
