Valve cover/crank case breather
JohnT24
OXFORD CT.
Does the international T444 use the same valve cover breather as the power stroke?
I’m stopping tomorrow at the local international dealer for some turbo O-rings.
Just wondering if they might have the breather O-rings also.
If so, anyone have a part number(s)
Parker, TX
International is the same as Ford. These are the part numbers I have on file:
Crankcase Breather O-Rings
(Ford) F4TZ-6769-A (small; seals screw head)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover)
(International) 1824452C2 (large; seals breather adapter to valve cover)
(International) 1820784C2 (small; seals screw head)
JohnT24
OXFORD CT.
Thanks again Pat.
I’ll bring those numbers tomorrow.
BTW
The only reason I’m going to international is because there is a dealer in a parts counter right down the street from me where I work.
KC turbo included O-rings
And they very well may be perfectly fine but, I just feel better getting factory O rings.
