swinky
What do yall use to get the gay off? Both corners of my truck are stained with gay...![]()
Fixed.
If a wax won't do it I'd just bump up to a light polish. I would think something as simple as a good wash would get it off.
I just made a purchase from CG. Got a little bit of everything. Im going to try out the Mr.Pink Super Suds soap, follow up with the medium duty clay bar, then the White Wax, and finish up with a coat of V7 quick detailer. Cant wait to get this stuff in and give it a go
Yea Im pumped. I did lots of reading on their site and plan to try a light polish this coming spring
Can you link some of the videos you liked for learning to polish?Also, I don't know if you found them, but they've also got a ton of how to videos on YouTube. That's actually where I learned how to polish.
Oh, and welcome to the addiction/obsession.
Believe it or not, I did that with a $45 DA from harbor freight. I read a few good reviews from pros using it as a backup on auto geek so I went for it about a year or so ago. Kinda intended on it being a starter one just to get the feel if I wanted to do it on my own.
Aside from the obvious build quality, like the handle threads only working on one side or the piece on the back not wanting to stay on it's really not bad. Some guys on auto geek said the motor is actually more powerful than the porter cable everyone uses.
The one downside is its balanced horribly. And by the end of a session you're beat. I went and read a little more on auto geek and turns out that's the backing plate and everyone says to replace it and it's much better.
Pics of results?My personal detailing regiment is as follows:
Wash: CG Mr. Pink (CWS_402) just with a good old bucket and CG mit (MIC_491) and don't dry it.
Clay Bar: CG Yellow OG bar with Luber. Comes in a pair (CLY_113). Clay bar the entire truck then wash it off again real quick.
Polish: CG Pro Polish 3n (GAP_108_16) its a very light polish with minimal cutting. I use it paired with a Porter Cable with the CG White Hex Pad (BUFX_104HEX6). Just go over the entire truck very lightly. Wipe down with a micro fiber cloth.
Sealant: CG Jet Seal (WAC_118_16) applied with CG micro fiber applicator (MIC_292_01) just apply a thin coat over the entire truck let it sit for 20 mins apply a second thin coat let it sit and wipe down with a clean microfiber cloth.
Wax: CG XXX Hardcore Carnuba (WAC_301) apply by hand with an applicator in thin coats and as many coats as you want. Wipe off.
^^^ Process above I do once or twice a year. and in between washes I use the CG Hybrid V7 Optical Select (WAC_808_16) which has some carnuba in it for a quick shine after a normal summer wash.
I had that one once. It broke with in 5 minutes of turning it on LOL they didn't believe that it wouldn't run at first when I took it back.
Have you seen the new torq DA that chemical guys just put up on their site this week? It looks really nice. Even has a digital display and when you switch it on it doesn't go all out no matter what. You just press the button and it slowly gains speed. Can't tell you how many times I forget I'm still on a high speed after I've moved to a new panel and have the product on the pad, and it slings all over the garage.
And whitemamba, have you seen the clay mitt? It accomplishes the same thing as the clay bar, but soooooo much faster. With my foam cannon I can coat the whole truck and clay it with the mitt in under 5 minutes, literally.
Finally had the chance to give some of my Chemical Guys products. Gave the truck a quick bath with their RU waterless wash. Pleasantly surprised with the results! But I did use the entire bottle....
Looks good. Kinda wanna try since it's so cold out but kinda like the old fashioned 5 gallon bucket sponge and hose.
Or a garage....When it's cold something that helps a LOT is insulated dishwashing gloves, and fill that bucket with hot sink water. Makes the process a lot more tolerable.
Or a garage....
