Wastegate Help
Blowby
I didn't use the shift input.
This is how I set mine up before I started using BP to drive the WG's.
Dieselboy.
Surrey B.C.
What size turbo are you running? On a waste gated Irate mounting kit?
FWIW, an h2e can be modded to a 71mm and I've seen it produce 590 rwhp on fuel.
S475 on irates mount.
I know. They're not as common. I just assumed 66mm. My bad.
Blowby
The same way you would if you were to use boost pressure. I use co2 on mine.
My race truck is a daily driver so CO2 was an option but I didn't want to worry about keeping it filled. Driving two gates and the action the solenoids see on the road (off the track) I would need another large tank to maintain the pressure to operate the gates.
