OSCS
Think my set up on my s366 and turbo smart gate is not how it should be. Anyone have pics of when they plumbed there's up?
Are there any advantages/disadvantages to one setup over the other?Many ways to plumb it.
- Manifold pressure on bottom with high spring pressure to control opening.
- Manifold pressure on top with low spring pressure allowing back pressure to open.
- Manifold pressure on bottom and top with specific spring pressure to control opening.
- Manifold pressure on bottom and regulated on top with specific spring pressure to control opening.
It's up to the builder or tuner on how they set it up since they will be determining the proper boost for your truck.
has any body run a electronic boost controller?
Right now, just trying to edumacate myself. I'm still running a stock turbo.Yes, depends on what you are trying to control boost or back pressure. Spring weight to max pressure desired, single or compound. Tell me what you are looking to achieve.
Setting up one now. I posted about it last month.
