Taylor D
Ideally where is how it works.
For starts let's say you want a max of 60ebp.
Scenario 1: you put the exact amount of springs to when the gate opens mechanically once 60 psi is reached.
(Perfect situation, except no adjustability without changing springs)
Scenario 2: you have too much spring and is makes 80 ebp and then you add boost pressure to help unload the spring pressure and open the gate. Unfortunately once the boost creeps up the more the gate opens and them then the less boost a ebp it makes. So them you add regulated boost back in the top to dial in and counteract some of the boost that's now opening it too soon. You tune it till you are able to repeatably reach 60ebp that you want.
(Most complicated and problematic)
Scenario 3: you have enough spring to where it will make 40 ebp. Then you add regulated boost to the top to hold the gate closed longer. Dial it in till it reaches 60 ebp that you desire. (The most desirable IMO)
With scenario 3 you can adjust ebp and if the adjustment fails it will stall make 40 ebp as a failsafe. Plus it is rock solid perfect every time. No fluctuation as you get with scenario 2 using two boost sources.
Great explanation Morgan wish I lived closer I could have u help
Do u know the spring combination to get the tial mvr to 40 psi and is that normally included with the gate or do I need to order some different springs?
Sent from my SM-G900P using Tapatalk
