Weird Problem with Passenger Side Mirror
OKState
Salado, TX
When I unlock the truck with the key fob, the passenger mirror glass moves all the way to the right and keeps trying to move until you hit the lock button or move the mirror with the mirror button. I reprogrammed the memory button to make sure that wasn't the issue but it still does it. Any ideas?
6.0dirtworker
Cloud 9
Wow that's really weird, never heard of that before. Wish I had the answer but Im far from it. Good luck.
OKState
Salado, TX
It definitely has me scratching my head. Going to pull the door panel off and make sure all the connections in there are good. Don't know where to start after that.
tensixniner
Is this with the factory keyless entry?
Sounds like some wires are crossed or shorting together.
OKState
Salado, TX
Well, took apart the door to get to the wires inside. No problems there. Traced the wires down to the fuse panel in the passenger kickpanel. No problems there. Got frustrated and started changing from memory 1 to memory 2 and the mirror magically stopped moving all the way to the outside. Everything is good for now. Little green men have been messing with my truck!
