Well **** me…
Mesa, AZ
Well short block is built. Gotta get in contact with rcd about thumper 2 hoops, if they’ll ever be off back order. Waiting on the new icon heads from kdd. Once they show up, gonna port match the Odawg to them and then tear em apart and send them for powder coat. After putting them on the race truck and seeing how much they stood out, I want to be a bit more stealthy. The 488 hanging over the tire shouldn’t give away too much… lol.
Anywho, the build as it’s going is o ringed .030 over block, kdd cut and coated pistons, callies rods, main studs, kdd stage 2 cam, arp 625s from the 250/100 motor that blew up, ati damper, sfi approved flex plate, warren 330/150 premiums, icon aluminum heads, new s2r Odawg, as I found my original one from 4 years or so ago was warped, (from back when Oliver was cutting them open, porting them, and re welding them), arp damper bolts, crank adapter bolts, and flex plate bolts, bd exhaust manifolds, and I dunno, probably more **** I’m forgetting…
Mesa, AZ
Nice man!
Still the stg 2 as the secondary?
Yeah, until it blows up it’ll be a stage 2 with a 488 out front. Welded in 4 bungs for spray, so there is a very good chance the stage 2 isn’t gonna survive at some point…
DEEZUZ
NO PUKESTERS
NWI
This is very exciting.
What's the part numbers on the engine side mount brackets?
SoGrand
MN
If you need a Thumper 2 HPOP i have a brand new one sitting at my shop. Don't need a core exchange either. You can text me at 612-812-6861 if you need it.
Thanks
Dan
Mesa, AZ
Thanks
Dan
Sent you a text
Mesa, AZ
Well finished building the motor Friday, got it put in Saturday and Sunday, fired it up Sunday and found a nice sized fuel leak. Finally traced it to my supply hose to the fuel bowl ****** decided it wanted to give up the ghost while sitting…. Ran to the shop and of course we didn’t have the air dog install kit in stock… so took Monday off and ran to strictly and got a new one, put it in and got it running. She runs very well now… traction is definitely an issue now.
Anywho we had our Xmas party today, and we ran at the drag strip. Did find it’s got a cut out issue up higher in the rpm’s. Gotta try and figure that out. Ran a best of 11.36 on a .136 jet. I was really hoping for 10.xxx…
DEEZUZ
NO PUKESTERS
NWI
One day ima be building something like this. Glad to see your making your way through some ****.
KCTurbos
It was awesome to see this thing in action at the track! Combo turned out great. But 6.0 tech needs to update his sig lol
