What are my exhaust options?
PsRumors
Cartersville, GA
Dad had a Banks downpipe put in years ago and had the stock exhaust straight piped.
What are my options that will connect to the Banks DP? Anything that will exit in front of the rear tire?
bad12jr
Why do you want it to come out in front of the tire? Then your wheel turns black. anything will connect to the Dp with the right size adapter.
samoht517
Lakewood, CO
In front of the tires is cool until you have to clean the wheel a few times. I think diamond eye has an exhaust that uses the factory flange.
Pstroke96
Connecticut
all i did was a 3" to 4" adapter about 5 inches of 4 inch pipe to put the two adapters together then a 4" to 5" then a 45 degree out infront of the tire
