What could be causing this?
wajackson79
I have an 06 f350 with 129k on the ODO. Bought it 3 days ago. When looking it over the truck was very clean, no drips, no blow by, nothing. Looking under it all was as you would expect for a 13 yr old truck.
I drove the truck 1600 miles home and today climbed under to change oil and fuel filters. The picture below is looking up at cylinder 8 (drivers firewall). I don’t see any wet spots anywhere else on the block.
During my drive home I checked the oil level a few times and it didn’t seem to move, and it never puked any antifreeze. No puddles aside from AC condenser. What should I check first?
Mesa, AZ
Check the cac boot at the turbo, as well as in the valley of the engine for leaks.
wajackson79
I’m not familiar with a cac boot. Sorry, first turbo diesel.
Mesa, AZ
Blue boot connected to the outle of the turbo. Cac stands for charge air cooler. You'll either have 2 and a black plastic pipe, or 4 if you have the metal pipe on the drivers side. The one on the passenger side right at the turbo is extremely common to leak. They'll get a little cut in them, or just start to swap thru. Id say probably 70% of the oil leaks I fix, are that cac boot.
