What Do You Tow?
TrailerHauler
Michigan
I love the stance on your dually. How hard was it to fit the f550 rear suspension? I'm wanting to run the exact same setup as you.
Thanks, if I were you I wouldn't do 550 rear leafs. They don't ride very well at all empty, and are only mildly tolerable with a load on them. If I did it again, I would just run the factory leafs with air bags, and blocks under all of it. Right now I'm running the top 5 leafs from a 550 leaf pack, and 4" blocks. The 550 leafs are about 2" shorter in length than 250 or 350 leafs, but bolt right in after the head on the centering bolt is narrowed down a bit. You would probably need a new centering bolt anyway after taking the bottom 5 leafs out of the 10 leaf pack.
But like I said if all your looking for is the stance, a 4" block will probably put you right were my truck sits. I'm hoping to pull those leafs out from under my truck possibly by the end of the summer to build a 4 link air ride suspension for the rear axle, and I think I will be keeping the same height because I'm also happy with the way the truck sits right now.
baddkarmaracing
harlingen,tx
First one is our race car trailer ImageUploadedByTapatalk1338257632.537330.jpg
Second is a 3car hauler that I moved a while back, had to pull one identical to this shortly after that had 3 axles under it, but we pulled the tires off the 3rd axle
Tow this more than anything though!
BigAlsPSD
Pea Ridge, Arkansas
Had a little work to do around the pool this weekend hauled this mini excavator
Usually hauling the boat
Other frequent haul is the 5ver
Couple months ago picked up a new DD provject for $350
blk99
first pic with CSIPSD's trailer
second of a trailer i have toted around for work
Poon
75 ft of lake fun.
Sent from my SCH-I500 using Tapatalk 2
Dustball8504
Everett, PA
Hauling my dads 69 AMC SC/Hurst Rambler from one deadbeat restoration shop to another shop to hopefully get it finished after over 3 years of little to no work being done on it.
dieseltron
Had to bring my buddy's 68 tempest to the motor builder.
this is just before we put more air in the trailer tires.
