Ok this is on a buddies truck.
A few weeks ago he called me the truck was gutless with the trailer, ran just fine at low speed and low demand. As soon as you would get after it there was just nothing there it would barely make 60mph. I was thinking plugged fuel filter. No codes. I changed the filter it ran like it should. I have autoE and nothing was showing up at all.
Now today running back to same symptoms. He took it to a shop and they told him it is a sensor out sending it too much fuel and making it run like that. They said the sensor was not to much money but it was $500 to put the sensor in. I am not real 6.4 savy but $500 to install a sensor ? or is that the standard open the hood charge? I was thinkin for him to hold off and bring me the truck and I would look at the filters and clean out the HFCM on the frame. Could there just be a bunch of junk in there? Where can I check fuel pressure on the truck and what should it be?
Thanks!!
I have a feeling they have gotten some nasty fuel since his daugters truck has the constant fuel in water light. So I think I need to clean it out too. I wonder if there both full of junk is why this truck is running like this.
Thanks!!
