SmokedF747
Jersey
Installed no limit fabrications 5" intake, color matched rim inserts, hydrodipped stars on the rims and color matched airdog filters
SmokedF747
Jersey
It holds up fine on my hot side and i THINK mike corsilli, guy with the fast 6.4, has it on his compressor side (i was told around 350*f that its fine) but i dont know for sure
tbsimmons
Bakersfield, CA
Worked on it. Split the bottom intercooler boot. Doesn't pull for crap with less than half boost and runs a touch hotter.
Sent from the bat phone near a drilling rig.
tbsimmons
Bakersfield, CA
lol.. that it does
Better than I thought when it happened. I though it was an up pipe. That would have sucked with the toy hauler 6 hours from the house. Luckily I bought a 2' stick of 3 inch intercooler boot material.
Good to be prepared.
RSK
Connecticut
Took the lift off.
Cory Anderson
looks good, I'll post up pictures of mine when I do my 4400lb coils up front and no rear block...are those wheels 20x12's? i'm running 22x10.5 with -25mm offset. should be fine if zip tie the fender liner back right?
JrStroker
Ahead of the competition
Yea they are 20x12. If I'm not mistaken you can run a 12 wide with 4400# with no rubbing. I know you can run 1.5" spacers on 12s and not rub with 4800#. So I'm guessing you wouldn't rub at all.
Cory Anderson
RSK
Connecticut
Cory Anderson
awesome! :rockon: how do you like the ride?
