greyford1979
Copley,Ohio
New CPS and took it for a test drive. Seems like it runs a little better but noticed a slight clunking noise. One of the exhaust hangers is a little too long and hits the frame:doh: :slap:
pa-powerstroke
Pennsylvania
4" Downpipe running to a 5" turndown behing the cab, sounds f'n awesome!! Also replaced my up-pipe gasket and a bolt on the top and a nut on the bottom, probably why my spool time seemed slooowwww
CSIPSD
Bend, OR
Unit bearings, I just squirt it into the air fitting when I think of it... only one of my U joints is greasable, the rear axle... The rest are still factory.
Main reason I did it is I have a vibration that I cant find. Going to get the wheels spun tomorrow and go from there.
Hoping its not something in the trans from my recent issue with a filter...
got ya... i had a wheel bearing start howling on me and i put grease in it like that but it tripped the abs light.... do you have to clean the hole out after or was it just a fluke deal?
hope its not in the trans.. that would suck.. seams like everyone's luck lately is down a bit..
CSIPSD
Bend, OR
I've always greased them from time to time that way. I dont use the air fittings for my truck, mine is a real 4x4 with a real T-case...LOL
come to think of it i may have went through the abs sensor hole... cuz i dont have air lines on the one i tried it on... imadumbass!
fordfreak4life
treated it like a cheap whore n flogged that bitch through the snow to work
Sent while spinning 18 wheels
Dmstrucks02
Pearland, TX
Pulled the tip off the exhaust, going to cut the pipe and put the tip back back on
SaNnDnSurF
SATX
Stared at it and wondered wtf is wrong with it and why no mechanic can figure out what's wrong with it :( seriously
rascal
TX
Ordered all my AIH & EBPV delete stuff and 4" Magnaflow exhasut kit.
I also ordered a new A/C condenser to dress up the front of the truck a bit.
Enslow
Baltimore County MD
Tonight after class i was planning on installing a 4" drop pitman arm and some train horns I've had laying around the house for past 5 yrs. Should be a productive night!
