What is normal back pressure numbers?
Bignbadbelair
Hey guys what is normal back pressure numbers on your trucks? I am getting 500psi also what units so you guys use to measure your back pressure?
Spatel23
Olive Branch, MS
Ummmm........you must mean 500kpa not 500 psi
500 kpa works out to about 72ish psi iirc
I assume you are monitoring with an SCT ?
Bignbadbelair
Ok it may be on kpa cause idk why but even in my boost whenever u put in psi it reads kpa readings and kpa readings is psi readings idk why but they are reversed.
Bignbadbelair
Got it changed to the right settings and I'll monitor my back pressure tomorrow and see where it's at. What's safe back pressure on these trucks?
Dan2427
If it maxes out at 72 what would be the problems to look for? Up pipes? Bad turbo/turbos? Sorry just trying to learn all I can since I'm still in market for a 6.4 and my dad had a 6.4 as well.
Poglife
Georgia
I'm gonna try custom tunes from gearhead I max my sensor out with my spartan and h&s with canned tunes
run a smaller tune.
getting custom tunes is a good start-then add a gate.
Jbird
Why do sct boost gauges have to be in in Kpa? If you put it in psi its throws crazy numbers
