Chvyrkr
- Joined
- May 18, 2011
- Messages
- 2,204
- Reaction score
- 0
One that opens valves?
Charles - It's all about the timing........Camless engines FTW! Infinately variable timing, overlap, and duration. . .
-Michael
-Michael
I got one going in the pullin truck. Supposed to really help in the upper rpms.....
Stock
Stock. "Keep it simple stupid" It works.....
That's the thing though... our available injection rate isn't really any better suited for much higher operating rpm than our stock cam profiles.
By the time you start making big power the required time to inject the necessary fuel with a Heui just isn't going to happen up top, making profile changes targeting those regions largely wasted.
Having seen your Stage 1 (and that looks good), can you tell me the difference between the Stage 1 and Stage 2 - ramp, overlap, duration?I've sold probably 15 stage 1s and 6 stage 2s and haven't had any complaints from anyone that wasn't tuning related and fixed. Running a stage 1 in my new engine in my daily driver and can tell you it does what I wanted it to do and more.
No, not ridden yet. Just the profile, which look good. I will be contacting you for a Stage 2 for the new build.wider LSA (to keep overlap still less than stock), .055 more valve lift, and 10 degrees more duration at .050 on both sides (aggressiveness about the same as the stage 1). The exhaust closing event starts to intrude on the piston so that's why it has to get a flycut for the exhaust valve only. There is no reason to open the intake valve any earlier than it does with a stock cam since the cylinder volume is at the minimum and there is no room to stuff air in anyway.
You have ridden in a truck with my stage 1?
You say its supposed to? Does it? Or did you just recently install it and haven't had time to really test it out?
Just playin' a little devils advocate with your choice of words
