What is this burnt oil? Picture
bigdirty
Looks like burnt bubbly oil. White smoke caused this. The turbo spins freely by hand, no binding. No shaft play.
TonyG
Elkton,Md
Yea I'd say a turbo seal is going bad, what's the inside of the intercooler pipes look like? Pull the boot at turbo and check it out.... Is it giving a constant white haze?
bigdirty
Constant white haze and its been real hot in PA 80s. Ill look tomorrow in the cac pipes
bigdirty
Nothing discovered in the IC pipe at the turbo. Dont know what else to check
bigdirty
Can a turbo be leaking but still make 25 lbs of boost?
a2elvis
If there is no shaft play then the turbo may not be bad. White smoke could be a lot of different things.
Poss CCV problem, injector?
bigdirty
ccv is dumped and injectors test good elvis. just dont want to drop 1000 for a turbo and not fix the smoke problem. if i take the turbo apart i will be able to see whats leaking right?
bigdirty
Can i replace these oil seals or am i stuck buying a new turbo? Like i said no shaft play, no binding of the wheel.
