What mods next?
kcstreetracer
I have a 2012 6.7 with the basic stuff done. S&b intake, 4" downpipe back, fully ******d, cold and hot side pipes, sct livewire with tyrant tunes. Midwest diesel transmission, 12" lift on 40's.
Thinking about gears to get some acceleration back from the 40's. What mods should I consider next? Injectors and lift pump? Bigger turbo and studs?
Thanks for any input guys!
Sent from my SM-G965U using Tapatalk
Get a larger drop in vgt turbo and either a 15+ fuel pump or dual fueler.
Sent from my SM-G955W using Tapatalk
08Monster
I would for sure do gears first, it will be your biggest drivability upgrade by a long shot.
Depends on what you want for a power goal, if you don't plan on going nuts, I would do a 15+ pump and a MPD budget kit with a 363sxe. Anything bigger would be a total waste with just a 15+ fuel pump. Honestly a 362 would still max a 15 pump.
Sent from my Moto Z (2) using Tapatalk
kcstreetracer
Thanks for all the input guys. Doing 4.10 years first then probably swapping turbos and the duel fuelers. The 4.10's with the 40's will give me a effective gear ratio of around 3.40 or so I believe. Trying to stay close to the factory gearing of 3.07.
Sent from my Samsung Galaxy 8 using Tapatalk
jcain
There's no such thing as 3.07 factory gears. 3.31 or 3.55 is what you had.
kcstreetracer
Well then the site I looked my axle code up lied cause that was what was listed. Guess I'll have to try again. Do you happen to know what the codes are?
