Cgrigson1
04 6.0'recently had no start warm one day it just shut off.
New crank position sensor and still wouldn't start
Towed to garage guy said it starts but I need hpop
Brought it home, I bought scangauge. I replaced IPR and then ICP.
It will start but runs very terribly and zero power will barely go 15 miles an hour and the transmission will barely shift.
ICP ref voltage is .01 KOEO. I have continuity from there it goes into to the CPU to the sensor. .05 v at the pin on the CPU.
Do I have a bad CPU? Most mechanics I have talked said they never have replaced one. Is there another test I can do?
Thanks in advance for your help.
