What would you call this piece on the engine?
DudeManScott
I'm assuming it's part of the oil system?
Sent from my SM-G950U using Tapatalk
79jasper
skiatook, Oklahoma
Mine would leak until the engine warmed up. Using the block heater would stop it too. Lol
Then I ordered the oring/gasket kit. Put that on. Realized the bypass valve was gone. So had to pull it again.
I put in the newer snap ring style.
Sent from my SM-G892A using Tapatalk
DieselDC
Thats a rebuild right there. Or get a new one if it's rustled out or really clogged.
DudeManScott
Correct. Is it leaking?
Here's what mine looks like from below. Not a very good picture but the part with all the sludge looking stuff is the side closer to the front of the motor. Not sure if all the stuff on the wiring is just road grime or something else.
I've never seen it actually leak oil on the ground I just see that sludge stuff there
