stroker2
Well im starting to look seriously into new wheels because i want to go with a 315/75 tire. The 285s just look to small since the 2.5" leveler and f350 block.
I am looking for wheels that will fit a 315 tire better than stock in both wheel width and to stay away from any rubbing if possible.
So my question is, what is a good backspace, offset, and wheel width to go with? I am looking at the mickey thompson classic II's (want to keep it simple). I would like to have a slightly wider stance but dont want to go to wide with the tires sticking very far out the wheel well. Im not sure to go with a 16x8 or 16x10.
The 16x8 has 4" BS, -13mm offset
The 16x10 has 4.43" BS, not sure about the offset
here is the page i am getting this from:
http://www.4wheelparts.com/WheelFinder.aspx?bp=8 on 170&cio=False&df=0&dt=0&finish=0&cons=0&ab=False&pg=1
Starting to lean towards the 10" wide but that seems pretty wide and could get into the fender wells pretty good If anyone has any pics of 315's and a similar sized wheel that would be helpful as well
Thanks!
Thanks!
