Which helper bags?
TxFireman1972
Beaumont Tx
Firestone Specs:
Max Pressure: 150 PSI
Duty Cycle: 25%
Flow Rate @ 100 PSI: .81 cfm
19 Amp
1/8" NPT Connection (male)
Stainless Steel Valves
Air Lift Specs:
Compressor:Super Heavy Duty
Max PSI:150
Duty Cycle:30%
Cu ft/min (at 60 PSI): 0.92
Cu ft/min (at 100 PSI): 0.74
18 amp
1/4" NPT Connection
Tree Trimmer
the duty cycle will kill you running small tools with it.
thats only 12 mins of compressor run time every 60 mins.
depending on what your goin to run for a tank, thats debateable on being able to change a tire with a impact.
the kits look quality, but if your thinking about using small air tools, you need a different compressor.
and as a side note, go to any semi repair shop, and you can piece everything together thats in that kit, except for the pump for around 30% of retail. fittings, hose, connectors, etc etc. least i can at mine.
and where did you get your deal on bags? im looking for a set.....
TxFireman1972
Beaumont Tx
Yeah I actually decided against those. This is the direction I'm leaning
Viair setup (with 450C compressor)
VIAIR 10007 Economy Version Constant Duty Onboard Air System | eBay
Then add the switch panel for my bags
200 PSI Dual Needle Gauge with 2 paddle valve switches | eBay
TxFireman1972
Beaumont Tx
Bumping it back up. My airbags are on, just need to get a compressor and maybe a tank ordered. I may just order a simple compressor for now, and new a more elaborate setup later.
Any suggestions on a simple compressor just for airing the bags up?
