6speedsd
Go about doing studs cab on? Seriously...I'm within a couple mths of doing mine. I don't have access to a lift. No way to get the cab in the air. So it's getting done in my driveway. I've seen where guys remove the EVAP box and jack up the engine from one side to the other to get the clearance they need. This was the way I had initially planned. Seen where others just pull the motor....now I'm considering this route. How much of a pain is it to pull the motor? I know the front end needs to come apart, which doesn't seem all that complicated...just time consuming. But othe than that, how hard is it to get that big bish out? Seems like that way would be easier and less of a headache than trying to pull the heads.
If you had to do it either of those ways, which would it be? And don't say pay someone with a lift to do it. I'm not paying huge labor rates for a job I can do myself.
