DZL JIM
This one has me a bit stumped.
When cold it fires up perfect, no smoke, runs great. After a few miles and you take off from a stop light it will nearly block out the road with white smoke. Only smokes when the turbo lags (6spd) and once spooled up there's very little and cruising there's none that I can see.
Seems like injector issue due to the strong fuel smell. However if you let it sit and idle it will smoke for a few minutes and clear up. Typical injector issues I have seen puke tons of white smoke.
Truck has been deleted, studded, etc, no tune. We put a good used motor in the truck that ran perfect before, I am confident it is not motor issue, however HPOP and injectors came out of this truck which was non-running when we got it.
Down pipe is wet with fuel.
Any thoughts?
Any thoughts?
