So why is it always cylinder 1 having the cylinder pressure issues? Every one always breaks the rockers on cylinder 1 as well when you turn up the HP. I am inclined to believe that number 1 is suffereing from some harmonic mojo on the crankshaft causing the piston to reach TDC out of time or the block is flexing causing the piston to have more protrusion than normal. OR...... is it the CPS causing a timing error on cylinder number 1?
