Luke@MillerPerformance
That came off a truck after 5000 miles. The filter element was completely full of that same rust/casting sand/mystery material. Truck was running ELC coolant and had been flushed before the filter was installed.
Do you have cited proof of this? Not saying you're lying, just the first I've heard of it.With the vt365 or 6.0 the engine has metal parts in coolant galleries that react to tap water. Something with the chloride in the water causes corrosion. The fix is not a coolant filter. Because on the navistar vt365 same engine in school buses and flatbed wreckers they have the coolant filter and still have problems. The fix for international was a complete flush of system and change over to the old green coolant with distilled water. Also with the sca additive for diesels.
What year of truck was this off of out of curiosity? Early?
True 2004. ICP on the valve cover but aluminum case HPOP.
I dont worry about clogging a new oil cooler. Yes it is always best to flush the system prior to disassemble, but in some cases, like a fully blown egr cooler or ruptured oil cooler, you cant run the engine. so in those cases its best just to pull block drain, T in a hose and run the water for a bit to get most of the debris out.
We clogged one oil cooler, 3 times... That was because the block was so far gone, the block would be flaking off after several heat cycles due to rusting of the system. The hoses themselves were embedded with a sandy orange rust. After the 3rd cooler, and yes there was a filter installed prior to all of this, we said the engine needed to be replaced as well as all coolant lines and radiator.
