Hello
Is there any reason an early 99 engine would not work in an 01 truck? If i just use the long block everything should swap over correct? Are the intake housings? (what bolts to the head) a different tube size? Hope that made sense. Will the early 99 injectors run with the 01 computer/idm? Thanks
