Will weak/bad HPOP cause...
David N
Eastern NC
A no start issue only when hot?
Its my truck in my signature. Just got my injectors back from Full Force, which are now 350/200's. It still won't start when hot. Starts up perfectly when cold other than a romp/choppy idle for a few seconds, then clears up.
It has new IPR and ICP sensors, new Mobil 1 5w-40 oil, and the reservoir is always full when the no start issue happens.
According to my AutoEngenuity, cranking while hot, ICP is anywhere from 250-350psi. While duty cycle slowly climbs all the way to 90-95%.
I have no idea on HPOP age, as it was on the truck when I bought it. I do know with my injectors that my ICP drops to 1500psi during WOT runs.
Any ideas?
Vader's Fury
Chesapeake City, MD
Yes it can. Sounds like somewhere you have a leak and once the oil thins out it leaks faster than the pump can make pressure.
I would isolate and pressurize each head just to rule them out for a leak then change the pump.
David N
Eastern NC
Yeah its leaking somewhere. What else could be leaking in the heads? Injector orings are new, and it has same symptoms as before I took them out, so I believe there aren't any cut.
Arisley
Arlington, Texas
How did the o-rings look on the injectors you pulled out?
You did slobber up the new injectors with oil on install, correct?
mandkole
Northwest
Agree. you could also cap and gauge the pump. The leak is in the pump or the head (s)
They were perfect. And yuppppppp. Oiled them up good-fashioned.
i use a gallon oil jug. cut the top off. perfect size to fit all 8 injectors. put injectors in and fill full of oil. works well if you leave the handle on too.. lol
David N
Eastern NC
Well I made a setup out of a grease gun to test each head.
Pumped them up to 3000 psi (which was kinda hard to get to) and shut it off. It took 55 seconds to leak down from 2700psi to 1000psi. Then another minute to leak from 1000psi to ~400psi. Which is ironically around all the ICP the truck will build when its hot and wont start.
Does this sound normal? Also, there is a small amount of oil coming from the weep holes on the back of at least 3 of the 4 injectors on the passenger side. I can't see the very back injector. I'd say each is dripping a drop every 2 seconds or so.
mandkole
Northwest
No, not normal-- it should be much more sealed than that and no oil dripping. The poppets are leaking and that is likely where pressure is bleeding, but could have an oring issue also.
David N
Eastern NC
I just got these injectors back from full force after getting the go ahead. They might have 20 miles. And I'm certain Orings are good to go. It's doing the same mess it was before I pulled them, and all orings were good then.
What's the next step?
did you isolate each head from the hpop? i assume you plumbed into the port where the hpop line goes to each head. or did you pull a oil rail plug and plumb into it there?
David N
Eastern NC
Yep I took the line off and plumbed straight into the head that way. Only oil passing I could see passing anywhere were out of the weep holes.
