H&S Bentley
- Joined
- May 20, 2011
- Messages
- 106
- Reaction score
- 0
Very awesome.
I assume there will be transmission options aswell?
Yes, we are going to provide full TCM control also.
Very awesome.
The more people respond to this thread the more excited I get with the answers from H&S
Bentley,
will there be detail for what each adjustment and parameter change will provide and or affect for the average person that is interested in doing this?
There are small explanations included with MCC. Most of the theory of operation can be learned with a little time using the tuning software. There will also likely be a lot of threads started online with info on what and where to change to achieve a certain result.
Most diesel ECU tuning is 90% the same. If you have used EFI Live or anything similar, this MCC software will come easy.
Most diesels you will see operate like this:
1. Pedal position gets converter to a desired torque value (pedal to torque tables)
2. That desired torque value gets used to determine a fuel amount (mass fuel tables)
3. Fuel amount is used to determine an injector opening time (pulse width table)
Simple as that! Then you just have to make sure you are not being limited by some maximum value or table of some sort. Really is easy once you break it down and understand how the software steps through the tables. It gets much much more complex when you see what all the ECU is really doing with the logic, but as for basic idea of operation it is simple.
This is so sweet! This is exactly what I was hoping for when I posted earlier in the thread. This is, in a nut shell, the same software I use to tune my car, so picking up on this should be a easy switch over!! Cant wait for it to be released
what models does the software cover? Does it work for 6L or do we get the shaft? LOL
Can you directly flash the pcm or do you need an HS device only?
Best thread to date on MMC. Thanks for starting it.
cant wait, looks like i mite not have to move over to sct after all
