You gotta be kidding...
Zmann
way too fast to read without manipulating the video
what did the info center pop up say ?
06Mud_Slut
That time it just says Door Ajar... but the video is about the truck dying right after it turns over. I think the first time it did it the a message popped up that said Check Gauges, but I can't be certain because it died right after I heard it pop up.
DEEZUZ
NO PUKESTERS
NWI
improper bleeding of fuel after a filter change?
oil gauge doesnt go up but it wasnt running long enough too.. I ve noticed lagtime in the gauge... especially if your using the wrong oil filter
06Mud_Slut
I got an Edge, and it's not telling me anything abnormal. There is a "Mod Volt" but I think thats the alternator. I did change the oil about 1600 miles ago, but I used a Motorcraft Filter like usual. Haven't messed with the fuel filter.
Cold Roller
Oakbank, MB
If it was a cold start and the timing was too advanced (extreme tune) this could happen, but not this time of the year and almost never in the lower 40 (8 might be cold enough in the winter). It could also happen with weak glowplugs.
06Mud_Slut
It did this 7 times total and still hasn't started... I don't want to keep doing it, and I have no way of checking my fuel pressure until I get a gauge. I was thinking something FICM or HPOP related... But that may just be me going worse case. I drove it this morning fine and then came back out about 4hrs later and it started doing it.
Big Angry Hillbilly
Codes?
I've had several start-stall conditions related to the cam sensor getting corrosion buildup behind it and pulling it away from the block, thus pulling the sensor end away from the timing pin in the camshaft.
Could be any number of things, even a stuck open EGR valve, or total loss of fuel pressure/volume.
A good scan tool is likely the next thing you're going to need to be into.
06Mud_Slut
No codes, and tomorrow i'm picking up a pressure gauge and voltage meter to check FICM. All I see on the forums here and other diesel sites are HPOP and FICM, and ICP; so I'm kind of expecting this to be a huge pain.
Cold Roller
Oakbank, MB
Loosing sync or FICM issues are the most likely. Without monitor, we all are guessing, but you had to have some fuel, hpo, and FICM injector sequencing to get the first burn.
Big Angry Hillbilly
It might be worth it to pay to have it diagnosed at a dealer who has a good diesel guy.
There's so many things that could cause this and the only scan tool in my opinion that does the job 100 percent is the IDS.
Mdub707
Mohawk NY
I've started and idled my truck with the fuel pump unplugged, doubt that's it, but possible I guess.
Mdub707
Mohawk NY
It wasn't done intentionally. I honestly had no clue it was like that until I tried driving it. Then I realized what I had done.
Demon
Alberta, Canada
Where are you tapping fuel pressure? I should check mine too.
Sent from my HTC Desire HD A9191 using Tapatalk 2
