Zerk fittings
RiVerBum01
lebanon, tn
Anybody know where all the zerk fittings are under a 01 ccsb 2wd? I'm a bout to go at it with a grease gun lol
PatriotHauling
Ventura, CA
I did, only found 3. Just seems like there should be more. That's was my reason for asking.
There should be 4 from the factory, but you may also find them on other parts if they have been replaced, such as u-joints, and ball joints.
Thanks for posting my video, have one on me. :pint:
You will notice in my video I have zerks on the driveshaft ujoints.. The PO replaced the u-joints and was smart enough to get greasable ones. Other than these 2, the rest (4) are factory.
Austin, Tx
I'm not sure I would call greasable u-joints a smart buy... Most greasable u-joints are some of the most unreliable u-joints out there. The OEM non-greasable Spicers are good for 300k+ in a lot of cases and they are stronger than greasable joints. No reason to go away from them unless you need a joint made from chromoly or 300M... My OEM spicers have 388k on them now and I hit them with over 500hp every day LOL
SD01WD
Greasing
After replacing the original stuff, I have upper and lower ball joints and tie rod ends and pitman end. Life is good now with MOOG.
