old96stroker
i recently bought a 2006 f250 eclb 2wd with the 5.4 and a 6 speed in it. the truck currently has 140000 miles on it, i bought it with 130000 on it. i am quite pleased with the truck and the way i have it set up, work truck with contractor shell but the transmission makes a lot of chatter at low rpm in low threw third gears, low-1st-2nd. my question is is there any kind of oil that will help with the noise i am hearing, i am told it is all normal and it shifts and operates fine so no problems there and the fluid level and oil condition looks fine, any recomendations on synthetics or anything to quiet it down? thank you.
