ZF6/ Tcase fluid change
TrailerHauler
Michigan
What's everyone putting in their ZF6 these days for fluid, and how many quarts? Same stuff in the transfer case?
For some reason I remember reading that most were running Motocraft ATF.
2000wa250
Im interested in this as well....not sure about the answer but I need to do it
Sent from my DROID BIONIC using Tapatalk
TrailerHauler
Michigan
mobile 1 synthetic ATF. 6qts for the trans and 2.5qts for the t-case. Both take the same fluid
Those numbers sound familiar, thanks! I run Mobile 1 in all my gassers and have always been a fan of it. I'll probably end up running that.
Anymore good input about fluid of choice is welcomed. I didn't see any other threads regarding manual trans fluids so maybe this will help others with the same question I had.
