ZF6 went Boom!
Barnbuilder
Waxhaw, NC
I'll check it. I ordered a new quill for the input shaft. Of course the first bolt snapped off trying to remove it. I'm going to try and drill it for an easy out and heat it.
Barnbuilder
Waxhaw, NC
Well finally got the truck back together. Need to finish modifying the clutch pedal. Put oilite bushings in place of the plastic ones. Just have to do the heim joint fix on the push rod to clutch pedal. November will make 2 years its been down. Having surgery on the 29th so need to get it wrapped up while still working and running the business and a new puppy.
Barnbuilder
Waxhaw, NC
Well got it together today and just got home from inspection. Windshield has a leak. Rear window has a leak from installing the later model window without a gasket. Couple other items to work on. Hate to but might be time to go byebye.
