01 ccsb build
Tmcclaugherty
Richmond va
I'm new to the diesel world and I purchased and 01 7.3 ccsb not too long ago and wanted to start building it.
for starters it has a afe stage 2 intake, 4 in mbrp exhaust, ts 6 chip with evil diesel custom tuning, and a heavy duty trans, converter and cooler
I would just like to get some opinions on the best way to build a somewhat fast truck, as it's not my dailydriver.I'd like for it to put down like 600-650hp lemme know what y'all think
dentexpowerstroke
denton, tx
300/200s and a s468 has seemed to be a fun/quick setup without going over board while still being very streetable. If I was wanting something that wasn't a competition level truck that's what I'd go with.
V-Ref
9 miles high @ 550 mph
Good looking truck.
Like was posted, probably be good to determine forged vs. pmr, and then set your power goals.
http://dieselinnovations.com/gallery2/main.php?g2_itemId=1524
A good regulated return fuel system, with a 20 micron or so pre pump filter/water seperator, and then a 5 micron filter post pump, would be a good addition to any truck. Here's a good start to building your own fuel system.
Bruce's 300/200s injectors would be a good fit for a forged rod motor, and are built by a real popular builder here on PSA.
There's a couple of TS chips in the classifieds already that you'd need to run those injs....but you'd need to get the PCM code DPC-4xx and XXX# off the PCM to ensure the tuning that came with those chips would work for you.
HPOP for a 200% nozzle...that's an open point right now. The only single pump that can support the 200% nozzle is getting beat up pretty hard right now (SRP1)...so you might look at a Gen3 or one of the dual pump setups...or just run a healthy single pump and know that in big PW tunes, you're not going to see the full potential of the injs.
There's a good deal on a S468 and TN up pipes/pedastal right now too.
All those parts ought to get you close to where you need to be with a good compression engine.
Head studs/pushrods/valve springs should be part of that at that power level.....and eventually the trans/clutch will need to be addressed too.
Hope that helps.
03ranger30
Mount Airy, MD
You should start by trading me your wheels and tires.....:drool:
Good looking truck though! Looking forward to what you do with it.
Pwnm30rdi3
Indianapolis, IN
Good looking truck.
Hope that helps.
I wouldn't suggest a Gen 3 for a DD street vehicle. They are great pumps for race applications but can be a bit much for the street.
I would suggest Dual Termies or Dual BTS pumps for 300/200's.
Waxhaw, NC
^^whs tuning is the key with that setup.
Gen 3 daily drives just fine no negatives as long as its ran with a stock HPOP
Sent from my DROID RAZR HD using Tapatalk
Tmcclaugherty
Richmond va
Sorry it's been some time but I've started getting some parts in because my fuel pump took a **** on me so I thought it would be a good idea to to start going bigger.
I ordered a fass 200gph lift pump and a sinister diesel sump kit for a little more flow🙈
Also I have a set of 250/200s coming from full force that I purchased from a member, here's a couple pictures I'll have more as more comes in, suggestions, comments, everything's welcome on what else y'all think I should get coming next and next step to the build 😏
It has ran 250/200s according to Jay. He said it doesnt hold commanded icp in big tunes but said the other single pumps didnt either.
I would probably get the gen 3 or twin terms if you wish.
cant believe that everyone is letting the gay ass sootlife sticker go unnoticed....
I couldn't read it. I thought it said saltlife but didnt look right with how I remember those stickers looking. Some jagbag had one at napa the other day. I asked him what ocean hes attached to 'round here. No answer.
01pwrstkr
Polk County NC
I live in western NC and I see those saltlife stickers everywhere!
swinky
Eastern, Nc
Try living in Eastern nc. People go to the beach once a week and think they're salty. I spend 200 days a year sleeping on a damn boat and wouldn't be caught dead with that sticker
Sent from my HTC One using Tapatalk
79jasper
skiatook, Oklahoma
Ha, I see those stickers all the time, here in Oklahoma. Lol
Most comon seen on Toyota fj's.
Sent from my SM-G900R4 using Tapatalk
