MY BIG 6.7 BUILD
Swsignal5
I figured I would start a thread on my build.
I first built a 61 VGT / 75 atmo compound setup and made 605hp. I've now stripped the motor and have decided to do a full build. Also bore the block .020 over.
I should start receiving parts next week. So far I've ordered the following.
Pte 68/70 gen2
Arp main studs
Chromoly pushrods
Valve springs
Stage 2 cam
R&r rods
Billet aluminum Pistons
Zero gap rings
H13 wrist pins
New OEM valves
New OEM gaskets and bearings
More to come:
Pte pro mod 102
Aeromotive fuel pumps
Big water to air intercooler
100 percent over injectors
Lots and lots of nitrous
Some trans parts
Some small secret things
...... Deleting the glow plugs.
Athens, IL
Looks good. Only thing I would consider is downsizing the atmo. Probably make about the same power with a 88-91 out front. And it would drive a ton better. Just my $0.02. Either way, at that power level your going to have a hard time keeping the bottom end and block together. Much less a Trans.
Powerstroke Man 6.4
Whats a estimate on the power of that setup?
Swsignal5
We're gonna see what those new main studs can do!
I also need to get some spring retainers from you
Swsignal5
Sent from my QMV7A using Tapatalk
