Who could this be about....![]()
Lol
I'm pretty sure Morgan at Midwest has some customers out there running his single kit modified for a Garrett ball bearing. He should be able to help.
Also, Cody @ ATP Trucks is running a GTX4088r as a single, that thing should be a riot when it's done. That's a 65mm I believe. The 4094 would probably be pretty great as a single as well. I think it's a 72mm
Yep, you're right. My bad. Hard to keep track of them the way they go by the turbine side for sizing.The 4094 is like a 68mm and a 4294 is around a 70-71.
What a/r Eric?
I got a GTX4294R here, its a 71 but haven't tried it.
What's the best cover for a gtx4202r that will spool quickly without scarificing a whole lot on the top end of the power curve?I've got guys with the gt4094 and also a gtx4202 as singles. Very pleased with them. Little more money but a huge step up in driveability.
Excuse all the questions, gotta learn some how! Lol! Is there a streetable single that would be around 800hp?? Or is a streetable single out of question for an 800hp build??
Off topic but does that thing surge or flutter a lot? I've heard horror stories about the wheels being so close in size causing a lot of surge.I'm enjoying my HTT S371, but I may try it at some point. They are hard to get a hold of so I'll hang on to it for now.
I know I wouldn't be towing. Just want a daily driver setup that would be around 800hp +/-. As far as streetable, I don't care if it smokes a little, but a don't want a huge ole cloud following me either if that makes sense. Lol!Depends on what you consider streetable.. It'll spool better than an s475 and some people swear those spool fine and others would never consider it. You won't be towing if that's what you're asking
