question on BW fmw 364.5
Fox hunt
Matt-Looked at your site and saw the prices but for this turbo with the 360 bearing, up pipes and all misc install parts what's one looking at cost wise(pm me if necessary)? If I ever jump to none vgt this is the turbo I wanna go with. Interested in results
Cutting-Edge Diesel
Newkirk, OK
Will do
JDub
Hooper, Utah
the 64.5FMW compressor flows nearly identical to the cast 66 found in a box S366, so power potential should be close between the two. The 70mm turbine is going to bring the power band lower in the RPM range though at the expense of slightly higher back pressure and egt's at the upper rpm range.
04cr450
harford county, maryland
^ good to know. this turbo(64.5/70/.91) should fit my application perfect being my driving is street majority of the time from 20-60 mph. can't wait to get it with the t4 kit
strokin6L
Springville NY
Egts and back pressure shouldn't even be an issue in the upper rpm range with that size turbine wheel and housing. When I was running a 64 non vgt t3 adapter flange turbo with stock up pipes....boost was 45 and bp was 54....stayed 1:1 all the way to 40psi. Max egts at WOT were about 1450-1500. This 64.5/70/91 should flow waay better with t4 divided pipes resulting in lower back pressure and lower temps in the higher rpms.
04cr450
Setup is awesome, ttruck has great power night and day difference from the stage 3 vgt turbo and 175/75's. Egts are lower as well with the bigger injectors.
I don't have dyno times or track times, will though shortly as I had some trans shifting issues but that is now corrected. I have put about 1200 miles on it and really enjoy driving the truck.
Fox hunt
That's crazy. Glad it's running good. In the future I might be interested in this turbo with some 190/30-50s
