I build everything myself. I enjoy fab work most of the times. I'll upload some more picsWho Built it? Got any non Edited shots of it? some more details?
Yeah I could have but when u do that angles are the devil when it comes to drive line to pinion, and the axles moving when the suspension travels. I did it like this for the way I'm using the truck. I don't plan on rock climbing and suchOn lifts like this.. is it possible to tuck the center section high and tight for as much clearance as possible?
It doesn't matter which way it goes. Depends on how I want the truck to move when it squats.Looks not too bad! You even got your rear track rod going the right way!
I tried not to keep track of the bill lmao. I probably have 15k. I have 5k just in rims. They have the machined windows painted the same Ruby red.Yeah if you don't mind the Queston what was the bill after EVERYTHING was done? Tires, the whole custom set up, I'm loving it!
Its in pieces again now but I put the pinion back in the stock spot now. I was having a little bump steer with it angled up.You even got the shocks with the reservoirs up front for the stabilizers!
Is it just the angle of the picture but it sure looks like your caster is a bit off? Got any better pictures of it finished?
Any videos of it sledpulling. I would love to see it.
