8WR_ZJ
finally got around to getting my new to me, and the first set ever of, aftermarket rims i have ever owned(big thanks to jomax on the deal hea gave me!!) and new 295/70r18 mastercraft cxt's.(dam things are rated for 4080lbs each[emoji106][emoji106][emoji106]) also got the new x4 tuner with ghead sotf from mikey installed(minus the swicth for now)... ran out of time. need to get to bed. will have to do that tomorrow. just left it in the tow tune for now. a big thanks to bigrpowr for the tuner too!! cant wait to try the sotf when i get it installed..
What is the offset on those wheels?
gotchadollar
Put a HSM 64.5 turbo kit, dual fueler, and lp pump on my 15
dsberman94
Pennsylvania
Warranty replaced a 2-3 month old alternator because it wouldn’t charge over 12v with no accessories on radio or headlights and it would drop to 11.6, glow plugs being on after startup it was down to 11 and dipping into the tens.
Mesa, AZ
Dynoed with a stock turbo for chits and grins. Did 511/1039 with water meth on, and 480/977 fuel only. It is a smokey ass pig without a big turbo.
got a 15 hpfp for it in the mail today. those are cute little units. i didnt realize how small they are. not much bigger then my hand. now i just need to get a turbo for it and swap it all at once.
8WR_ZJ
Fight the masses to go get some batteries. 2015 truck 60k miles, both are shot. Sad.
Batteries don’t last. Mine went out in 1.5 years but with 70k miles iirc
C2tuck
North Texas
I just rolled 40k tonight on my ‘15 and the terminals are already caked with corrosion...sure it won’t be long for me either.
my 12 still has original batteries with 113k miles on it.... knock on wood.. lol
ummmm, that just means it has been wet a few times. that is a natural reaction. you are supposed to clean the posts off every year..
Mesa, AZ
Lately motorcraft batteries have been cracking quite often. Better get that chit clean before the cable end gets eaten. Unless they are replacement motorcrafts and you have warranty. Cant tell you how many sets of battery cables ive done on these, and they suck major donkey balls...
fine69
Cranberry Twp,PA
my 12 still has original batteries with 113k miles on it.... knock on wood.. lolummmm, that just means it has been wet a few times. that is a natural reaction. you are supposed to clean the posts off every year..
My 09 still has the original batteries, but it only has 25,000 miles on it.
