Leveling kit biggest widest tire setups?
smokedout250
harrisburg oregon
Hey guys,
I'm working on getting a specific look. I'm gonna be running a 2.5" leveling kit on my 07 250. I want to run 35x12.50r20 tires. What I'm looking for is guys that are running a wide offset. How wide? What mods to make it work. I'm wanting to fill the fenders and give it a low aggressive stance.
Ps. Pic are always welcome thanks for the Info in advance!
Black_Pstroke
Evansville, IN
2.5" 35x12.50 toyos, 20x10 -24offset fuels. Minor inner fender well trimming
powerstrokin15
Charleston, WV
thats an 08+ truck. they arent exactly the same.. mine is the same setup, im running no leveling kit, and barely rub the liner.. but like i said before- i sold the SAME setup to a guy with an 05 truck-leveled, was literally way to close to the fender and bumper.
Denver
America
Bilstein leveling kit with 18X9 -12mm offset and 325/65/18 Toyo's. This is on an 05
smokedout250
harrisburg oregon
I knew the 08s were different but judging by this pics -12 is all I can run.... Thanks guys! On a side note how do they clear the bumper? And what about the radius arm?
SLOSIXOH
I have 35x12.5x20 Toyo tires on my 06 truck with no rubbing issues. I have them on stock Harley 20in rims. I used rubber coil spacers on the front with stock F350 blocks in the back. I love the stock-like ride quality with out doing a big suspension lift.
smokedout250
harrisburg oregon
Clearing 35s won't be a problem but gettin the offset as far out as I can is where the challenge is I can't run what I want with out goin to a 33 and to me that makes the tires look to small on a 20" wheel....
Black_Pstroke
Evansville, IN
My bad man I wasnt paying attention to the years you posted up. Heres some pics from my 06 with 35x13.50's on 20x9 with -10 offset. With a 2.5" Lift
After I noticed it rubbed the airdamn I took a heat gun and trimmed/molded it, no more rubbing there.
Also had slight rubbing here so I took a ballpein and a wood lathe and slightly rolled this panel in took care of the rubbing issues completely. I didnt have to trim any of the inner fender on this truck.
smokedout250
harrisburg oregon
my next setup will
be 20s and 33s. and I'm offroad quite a boy.
Eric@HolderdownPerformance
There is a plus to 33s they are cheaper! Lol idk yet what I'm going to run yet had 35s on my obs never really do any serious off road stuff mainly check fields and go hunting. I know the 35s are gonna hurt my mpg so the more I look at 33s there are some plus to them
smokedout250
harrisburg oregon
So from the research I have been doing I plan to run a nitto trail grapplers, now they make several sizes in a 20" rim so that are only 12 wide and 35" tall and they make a LT305/55R20 E 121/118Q which is a 33.39x12.60r20 would I be better off running the 33.39 or a narrow 35?
strokin20
brownwood, tx
33x12.5x20 on 20x12 hostage. 2.5" leveling kit. had to trim the fender liner a little bit.
