How much horsepower?
P.I.S_7.3
TAMPA FL
trying to get a rough idea how much horsepower my combonation of parts makes thanks. will be dynoing on a mustang 1100se dyno next week.
P.I.S 238cc/200% injectors
38r turbo
stealth srp1 hpop
walbro 392 fuel pump
regulated return with sump
headstuds
comps 910s shimmed
suncoast tranny
6.0 intercooler
no limit tuning
Powerstroke Cowboy
Montana
Depends on the tuning.. Do you have a external gate on the 38R?? Or is the gate still factory??
Depending on.. You could be around 500 to 550 with the 38R dialed right and good tunes..
P.I.S_7.3
TAMPA FL
Tuning is by Jonathan at No Limit tuning & design formerly of beans diesel.
no sir my 38r has the factory wastegate. It has been cross drilled and has a hi flow flange
Powerstroke Cowboy
Montana
OK should be in the range I guessed... Would be shocked if it was lower..
That also depends on the dyno.
thoroughbred
BG KY
your set up is the same as mine except I'm running 238/100....
on johnathan's dyno I pulled 570HP/1150TQ in December
I'm interested in the difference the nozzels would make
P.I.S_7.3
TAMPA FL
wow those numbers are way higher than i thought possibble with a little old 38r. But im not live tuned
thoroughbred
BG KY
http://dynoproven.com/blog/?p=4
At beans in november I pulled 561hp/1105TQ
The december dyno was live tuned but `before that it wasn't
Johnathon's dyno was down when I finished mY build in august so he loaded tunes he thought would work.... He got pretty close
CSIPSD
Bend, OR
His dyno numbers will NOT match is track times... Not even close.
His set up is a 470-500 hp tops.
Petro
Lincoln Nebraska
Joe, in your opinion how much of a difference are the 200 percent nozzles going to make compared to the 238/100s that were just mentioned?
CSIPSD
Bend, OR
IMHO about 30hp... Maybe 50 depending on HPO pressures and such.
P.I.S_7.3
TAMPA FL
I had 100% s on these same injectors. I like the 200% s way better. Definitely more power. 50hp sounds about right
Tim @ P.I.S.
Sunny, FL
With the history i have seen with this dyno, my guess is 456.
We just did 155 on it with a stock 96'.
Added tuned chip and did 190.
Dynos are for tuning. Start with one and stick with it. You cant jump around, unless you are just trying to win trophies.
