01 4R100 won't shift into 4th
Lang
Got home this morning, shifted fine otw home. Left her running in the driveway, grabbed some stuff for my other job, backed up, pulled out, won't go into 4th. Parked til I get done today. Where should I start looking?
RNicol
Milford Center, Ohio
It could possibley be a Solenoid Pack issue, and if you have a TS style chip, make sure it is making good connection because that can make the trans shift weird too.
Lang
Well went to go drop it off at home, won't go in reverse. Mechanical linkage is correct, just no neutral or reverse.
Mark Kovalsky
SE Florida, USA
Here's how you troubleshoot a torque converter: Does it move in either direction? If it does, the problem is NOT the torque converter.
