02 wiring in a e99
rat49f6
Vernon,NJ
Im getting a 02 donor this weekend for the full cab harness will this interfere with my e99 engine harness or pcm? Any other issues you can think of?
Sent from my SGH-M919 using Xparent Green Tapatalk 2
CSIPSD
Bend, OR
You wont have a AIH, you can cut them out of the harness...
Come to think of it, there are some changes in the pin outs, but I dont recall if its at the harness or the PCM...
You would be better off with a 2001-2000 harness, then the only change would be the AIH...
rat49f6
Vernon,NJ
Alot of stuff will be deleted so that's not an issue. The bagged truck in building will be getting an engine bay wire tuck so the 02 harness is a much better option simply because all of the fuse panels are inside under the dash. I guess ill just have to find a 02 pcm and engine harness then too ... not a big deal
co04cobra
WV
You will have a ton of issues trying to get a 99-01 harness to work with a 02-03.
Damn near every aspect from the harness behind the dash, to engine harness, trans harness, etc.... all changed in 02.
If you have a donor truck swap ALL of it.
rat49f6
Vernon,NJ
Pretty sure I can get it all except trans harness as the donor is a auto mine is manual
